Will it be good enough?
Discussion in 'Subwoofers' started by Wild Rumpus, May 12, 2005.
  1. Wild Rumpus
    Wild Rumpus
    Mar 30, 2005
    138
    Erskine
    After my recent post on Subwoofers at low SPLs I have decided to take the plunge and buy a 'woofer. I want something fairly small and with a wood finish. My system is Denon 3910/3805 into Linn Ninkas, AV5120 & Uniks. Would the BK XLS200 be a worthwhile purchase? My room is around 14'6" X 12'6". If not the BKs then what would you recommend? I'm prepared to spend up to around £700, but don't want anything much bigger than a 16" cube.
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    BKXLS200 would do a great job, it's diminutive size will fit the bill, the wood finishes are excellent. It packs a very powerful punch yet also does great work at low sound levels (the way I usually listen to it). Way way under your budget too!
    :) ...PJ
  3. shodan
    shodan
    Dec 11, 2001
    11,539
    shoeburyness
    +6,432
    Way eay under your budget so you could get two of them and have it even better!!
  4. Wild Rumpus
    Wild Rumpus
    Mar 30, 2005
    138
    Erskine
    Yep, way under budget is a good thing :D I'll see how I get on with one and maybe upgrade to two at some stage. Or I might just buy a nice DVDR/HDD machine with the excess cash. :clap:
  5. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,080
    notts.
    +63
    Try and get a demo of the B&W ASW675 a very good compact sub and it looks very good also.
    Cheers Gonzo.
  6. doctorjuggles
    doctorjuggles
    Aug 31, 2004
    799
    London
    +19
    I've got the ASW675 for a room that's a very similar size to yours and it performs amazingly well. I can't believe the huge noise that such a tiny box can make, and I'm also impressed with how it performs with music.
  7. KHCC
    KHCC
    Aug 10, 2004
    256
    Kent
    +10
    Mornin'
    Have you thought about the MJ Acoustics REF200! Just under budget and an awsome sub.
    Regards
  8. Wild Rumpus
    Wild Rumpus
    Mar 30, 2005
    138
    Erskine
    Yes - the B & W and MJ models had crossed my mind (along with REL). Has anyone compared any of these three against the BK?
