Will it accept a HD signal?
Discussion in 'Plasma TVs Forum' started by Kendilian, Aug 28, 2006.
  1. Kendilian
    Kendilian
    People, ive been reading though the manual for my 42" JVC GM-V42EB monitor and it states in the manual it can accept HD signals via component?
    it reads;
    'You can select one of the High Definition (HD) signal types through the component/RGB terminals - 1080i or 1035i. Normally set it to 1080i
    Now am I getting my wires crossed (no pun intended) does this refer to signals from PC's or will it take signals from Sky HD or a HD DVD player?
    It certainly wasnt advertised as HD ready
    I pray for your expert opinion!!!
  2. THERAAAVEN
    THERAAAVEN
    Jan 31, 2006
    587
    ruislip
    +10
    Not Hd Via Composite - But Maybe Thur The Component
  3. Kendilian
    Kendilian
    *edit* thats what I meant, cheers
  4. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    HD Ready means more than just being able to take 1080i, you need to take 720p/50, 720p/60, 1080i/50, 1080i/60 and support HDCP. So the chances are it does support HD but can't be labelled as HD Ready.
    Just checked the manual and it takes 480p/60, 576p/50, 720p/60 and 1080i/50 but not 720p/50 so fine for SkyHD for example over component.
    Native res is only 480 lines but you'll still get a better picture on HD stuff.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    until HDCP becomes an issue you should be fine feeding 1080i from sky HD etc
  6. Kendilian
    Kendilian
    Nice one, cheers
