will ipod work on usb 1.0
Discussion in 'Headphones, Earphones & Portable Music' started by plasmosis, Jan 24, 2005.
Tags:
  1. plasmosis
    plasmosis
    Jan 17, 2005
    68
    london
    Quick query guys and gals, will an ipod work via usb 1.0?
    and will the software work on a pentium II pc with windows XP? :blush:
    Much obliged.
  2. mick's cat
    mick's cat
    The answer to both should be yes. But USB 1 will be s-l-o-w... Best to buy a new card - USB 2 or best, firewire.
  3. plasmosis
    plasmosis
    Jan 17, 2005
    68
    london
    Thanks mick's cat. Any suggestions where I can get a usb 2 or firewire card?
  4. mick's cat
    mick's cat
    The Belkin range of cards seems to be pretty good, with good support, although there are many others. Staples, PC World etc have them on the shelf and should be able to help. Best of luck.
  5. davet010
    davet010
    Jul 23, 2004
    385
    +10
    I got a Firewire card for about £15 - very easy to fit.
  6. w3dal
    w3dal
    Aug 4, 2002
    5,053
    Chelmsford, Essex
    +588
    i think u need to be running SP2 on Xp aswell.
    i use usb 1.0 on my pc at work with my ipod. it is slow but its not as bad as u think.
    Dal
  7. petecowie
    petecowie
    R.I.P.
    Sep 3, 2003
    884
    2
    Essex
    +42
    I bought a firewire card with lead and shipping via ebay for £10 came from Hong Kong in under a week so worth checking. I would reccomend going for a combi firewire USB2 card you never know when the other will come in handy. Also have connected mine via firewire on XP before (and after) I installed SP2.
  8. plasmosis
    plasmosis
    Jan 17, 2005
    68
    london
    Thanks for everyone's helpful advice. Looks like I'll be getting one since there shouldnt be anyprobs using it on my 'ancient' lap top...hehe.
    sorry I'm not very it literate, could some one tell me what sp2 is and where i can get it? Correct me if I am wrong but I only need the sp2 software if I intend to use firewire right?
    petecowie, the place you got the card from hong kong, is there website or contact detail if you dont mind me asking? sounds like a good buy.
    cheers.
  9. mick's cat
    mick's cat
    Just a word of note. Apple specifies:
    http://docs.info.apple.com/article.html?artnum=60971
    that an iPod needs USB2 or FireWire. Can't say for definite about Windows, but an iPod won't work on a Mac with only USB1 (actually, it's iTunes that won't allow the iPod to work - other music playing apps like Audion *do* allow the iPod to work with USB1). iTunes on Windows may be different...
    Apple also has a list of known working USB2 and FireWire cards here:
    http://docs.info.apple.com/article.html?artnum=93405
    Other cards may work of course, but you may not feel like taking the risk. Keep us posted.
  10. petecowie
    petecowie
    R.I.P.
    Sep 3, 2003
    884
    2
    Essex
    +42
    my brother definitely uses his on usb 1 on xp non sp2 so does work.....
  11. plasmosis
    plasmosis
    Jan 17, 2005
    68
    london
    ok...will try it with usb 1.0 without sp2. If too slow will then look for the firewire card. Soory to ask again but whats sp2???
    Now need to get my hands on an ipod :) any suggestions where I can get a good deal ? ipod 20G preferably.
    cheers
  12. petecowie
    petecowie
    R.I.P.
    Sep 3, 2003
    884
    2
    Essex
    +42
  13. plasmosis
    plasmosis
    Jan 17, 2005
    68
    london
    jus quick note to thank everyone for their advice and help. now need to go find meself an ipod....
    cheers
