will i tell
Discussion in 'AV Receivers & Amplifiers' started by luv ya jen, Jun 16, 2003.
  1. luv ya jen
    luv ya jen
    hia peeps im after getting a marantz sr 4300 from rs at the mo i have a sherwood 6103 amp running with a set of eltax liberty i will be part chopping the sherwood so i cant really try them both side by side my main question is what makes the marantz better than the sherwood if it is better??????
  2. cosmic023
    cosmic023
    Feb 15, 2003
    1,369
    48
    Somerset
    +87
    Hi Luv,
    I tested a Sherwood 7100 pro logic amp at home for a week, as part of the try it at home deal, and i hated it, very messy controls and sounded very naff.
    I held onto this amp, while waiting for stocks of the SR4300 to come into my local branch of RS.
    When i finally got the Marantz, WOW what a difference, the sound quality on music duties was AWSOME, and it still is. It's the best sounding AV amp i've heard from RS when i was looking for an AV amp.
    I did try the Yamaha 630 RDS, and the Kenwood (Can't remember the model), and the Marantz SR4300, and a Denon 1602 (Was no longer in stock which was a shame, as this was my ideal amp). And guess who won that deal
    Some poeple prefer the Yamaha, but for music & movie duties it's still a winner.
    Cosmic023
