Will i need a router?
Discussion in 'Xbox Forums' started by sting£r, Jan 2, 2007.
  1. sting£r
    sting£r
    Apr 14, 2006
    315
    +13
    I have a DSL modem, no router, do i NEED one for online gaming, or can i just plug in the xbox, and when im done plug it back into the computer?
  2. noshoulders
    noshoulders
    Apr 5, 2005
    451
    28
    +29
  3. madhouse
    madhouse
    Nov 11, 2005
    399
    28
    Bawtry nr. Doncaster / Wiesbaden (Germany)
    +72
    as long as you can enter your login details somewhere on your console you should be okay. If not, you'll need a router. Then you'll enter the login details in the router software and it will get you online whenever a PC or game console requires an internet connection.
    Hope this helps.
    Simon
  4. Tezcatlipoca
    Tezcatlipoca
    Jan 2, 2007
    139
    +9
    If your DSL modem is ethernet, rather than USB, then I think you should be able to connect it directly to the 360.
    I'd recommend getting a router though (maybe a combined router / DSL modem). Much easier. No need to swap over each time.
  5. wormvortex
    wormvortex
    May 29, 2005
    5,761
    South of Heaven
    +442
    I've never entered any personal details into my router and i can connect anything to it just fine. The only thing it knows is the ip address.
  6. brandondanger
    brandondanger
    Nov 23, 2005
    708
    dudley
    +10
    ive got a motorola modem from telewest, pc is connected via usb and xbox is running through the ethernet port, can use them both at the same time. no routere needed. and much simpler than using a router too. just enter your ip address into the xbox and away you go.
  7. Tezcatlipoca
    Tezcatlipoca
    Jan 2, 2007
    139
    +9
    I didn't realise Telewest still did that.
    ntl used to offer a "Broadband & Console" service, where you got 2 IPs instead of one, but ditched it when they brought in 10meg IIRC.
