Will I need a new dish for Sky HD?
Discussion in 'Sky Digital TV Forum' started by damo_in_sale, Sep 17, 2005.
  1. damo_in_sale
    damo_in_sale
    Jan 3, 2005
    2,819
    +507
    Hi chaps,
    I live in an apartment block so geting a satelite dish installed isn't all that easy. Do any of you guy's know if I will be likely to get Sky HD without having the dish replaced? I have Sky+ so have two coaxial feeds into the apartment but might I need more? If so then I don't think it will be possible.
    Cheers,
    Damo
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    The HD channels will be from the same satellites as the SD broadcasts and will be received via the same dish/lnb cabling. SKY+ HD will require two feeds just as the normal SKY+ does and I suspect quite a few people will be doing a straight swap from SKY+ to the new SKY+ HD.
  3. damo_in_sale
    damo_in_sale
    Jan 3, 2005
    2,819
    +507
    Thanks Starburst, guess that means I will be ok.
    Cheers,
    Damo
