Will i loose PQ with a 10m hdmi
Discussion in 'Cables & Switches' started by wallzy, Mar 9, 2006.
  1. wallzy
    wallzy
    Jan 26, 2005
    562
    +16
    ive had to move my reciver to the other side of the room now i need a 10m hdmi lead to connect it to my projector will i loose much picture quality with it bein such a long run
    thanks
    wallzy
  2. cheechy
    cheechy
    Jul 14, 2005
    526
    +12
    My personal opnion here is that yes this would work but at lengths like these the quality of the cable is paramount.
    Something like a bettercables HDMI cable may be the way to go.
  3. wallzy
    wallzy
    Jan 26, 2005
    562
    +16
    thanks for your reply do you have any idea how how much the quality will suffer with a cheaper cable
    thanks
  4. ailean
    ailean
    Jan 17, 2006
    586
    43
    +153
    Being digital you'll find it either works or it doesn't, typical errors appear as white specks or lines and the results can vary depending on the power/sensitivity of the transmitter and receiver at either end.
    It's worth avoiding using adapters (if you have a mix of DVI/HDMI) as they can degrade the signal and at 10m you want to avoid any more loses.
    If possible get one from somewhere that accepts returns as results vary on different kit, also test every res you want to use (I've got one 10m that works fine for 720p and 1080i but has speckles at 480p/576p :confused: ).
  5. wallzy
    wallzy
    Jan 26, 2005
    562
    +16
    thanks for your reply also the lead came today ive connected it up and all seems fine carnt notice any PQ differnce
    thanks for the replys
