Will HTPC on Sanyo Z1 better than Philips 963SA ??
Discussion in 'Projectors, Screens & Video Processors' started by AVJ, Jul 7, 2004.
  1. AVJ
    AVJ
    Hi all Sanyo Z1 owners !
    I am currently using Sanyo Z1 with Philips 963SA.
    Will it be better to use HTPC to drive the Z1 ?
    If so, what should be the HTPC config ? (hardware & software ?)
    what should be the best setting ?
    If not (i.e. the 963SA already good enough), how do you guys having
    both the Z1/963SA like me setup your system ? what is the setting in
    both the DVD player & Projector ?
    Looking for your help & thanks !
