Will Horrizontal side shift lesson quality?
Discussion in 'Projectors, Screens & Video Processors' started by ScouserAndy, Apr 21, 2007.
  1. ScouserAndy
    ScouserAndy
    May 30, 2004
    952
    Merseyside
    +22
    I know keystone adjustments do, just wondered if the horrizontal and vertical shifts will lessen the picture quality?
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,998
    UK.
    +3,449
    They do have an effect and it can vary from pj to pj. In some cases it can exacerbate chromatic aberration, alter center to edge focus or reduce contrast and light output. In most cases you probably won't notice the reduction unless the CA is very pronounced or the focus is noticeably blurry. Try it and see if you notice any reduction in image quality. If you do, try to find the optimal position for the lens and then place the pj accordingly.
    Gary
  3. ScouserAndy
    ScouserAndy
    May 30, 2004
    952
    Merseyside
    +22
    Thanks.
    I couldnt see any difference. I have sky HD feeding my Panny AE500. Each feed to the pj seems to have a different picture position. Fed up with moving the pj bracket slightly everytime!
