Will Freeview work with a TV without a scart socket
Sorry to go over a topic that's already been covered countless times but I'm really confused about whether I can get Freeview to work with my TV. It's an old Sanyo TV which doesn't have a scart socket but does have a white audio input and a yellow video input. I'm confused because the majority of posts I've read here and elsewhere have stated that Freeview will only work with a TV without scart if the Freeview box has a built in RF modulator or if a seperate modulator is used. I've also read one or two posts that have said a scart to phono convertor can be used if the inputs are available on the TV. Am I correct in thinking I can get a Freeview box without an RF modulator and use a scart to phono convertor with my TV?
Thanks for your time and help.
ianh64
Yes. You can either use a Freeview box that has an RF modulator (not to be confused with RF passthrough) and plug it on to your aerial input on your TV or you can buy a SCART to composite (yellow) and audio (red/white) phono. Some Freeview boxes have an audio mono/stereo option for TV out so you only need to use either red or white audio lead into your TV.
Chris Muriel
Or, if you have a video recorder, use its modulator.
You can connect via the Freeview box's SCART to the VCR's A/V input SCART and use the VCR's RF (coaxial) output to connect to the TV's aerial input.
Chris Muriel, Manchester
Andy98765 said:
Never heard of one, and boy that must be an old TV.
Yep. It's about 16 or 17 years old. Still works so I've no need to replace it yet. Hopefully it'll go bang sooner or later :)
Thanks for the information. I was looking at the Wharfedale DV832B that's sold in Argos so hopefully that'll let me change the output to mono.
Haven't got a video player but thanks for the suggestion.
N
Noremac
If you have a TV without a SCART socket and wish to receive digital TV you should try the Micro Freeview Receiver from TVonics.
The MFR-200 is very small, and has all the functions of a standard freeview box. I tried it and it worked first time. Cheaper than some others at under £40.
fernandez
Welcome to the forum:)
Considering this thread is almost two years old, and the OP has only posted here twice since then, he most likely has a new TV (probably Sony or LG:cool:) with a Freeview tuner.
Similar threads
The Best Movies and TV Shows Coming To Amazon Prime Video in August 2020. Tom's Thumbs.
