Will DVI-I Accept DVI-D ?
Discussion in 'Cables & Switches' started by DragonGH, Oct 19, 2005.
  1. DragonGH
    DragonGH
    here is the problem,
    I have just ordered myself a Hitachi 32LD7200, which i am planning on connecting to my pc via DVI... but here is the problem, the 32LD7200's DVI connection is a DVI-D but my graphics card is a DVI-I.
    Would a standard DVI-D to DVI-D cable be ok as a DVI-I connection will accept both analogue and digital signals :confused:
  2. MikeK
    MikeK
    Oct 9, 2004
    2,231
    83
    +316
    Yes!
    DVI-I sockets are compatible with DVI-D plugs - however the reverse is not true!
    All that happens is that the analogue signals presented at the DVI-I socket on the graphics card, are not transferred down the DVI-D cable - only the digital signals get transferred!
