Will DVD+R in the USA
Discussion in 'Blu-ray & DVD Players & Recorders' started by Leeray3, Nov 17, 2003.
  1. Leeray3
    Leeray3
    Jan 22, 2001
    149
    London
    Basically I have a Philips 880 DVD Recorder.
    If I record onto a DVD+R will it work on a DVD player in the USA?
    Does the player need to be multiregion or just accept the DVD+R format?
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    In theory it will play fine (assuming the play is compatible with DVD+R). However note that most US players cannot handle PAL - so unless your recording is in NTSC then it probably won't play. That said it will play in a PC based solution like WinDVD without problems.
    The question of multi-region is totally academic to DVDRs - it's is effectively a Region 0 disk (i.e. plays in any player).
  3. ivanwilson
    ivanwilson
    Oct 31, 2003
    111
    Belfast
    Can the Philips record in NTSC?
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    As far as I can remember the 880 can record in pure NTSC or pure PAL. Most DVD recorders can as it happens.
  5. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    Yes but only from an ntsc source, they won't convert from one to the other
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    That's what I was implying (not very well) by saying "pure" PAL or NTSC. It should be noted that it can't record PAL60 sources either (i.e. a PAL VCR which is "NTSC compatible").
