Will DVD Players Play CD- ROMs?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Garrett, Sep 5, 2003.
  1. Garrett
    Garrett
    Apr 21, 2001
    33,601
    2
    167
    The best thief you’ll never see.
    +4,471
    Can anyone tell me if the newer DVD players will play CD ROMs?
    If so how do you get one to play on a Toshiba 330?
  2. Easy2BCheesy
    Easy2BCheesy
    May 8, 2003
    343
    16
    Er, CD-ROM? You mean CD with PC code on them? No, they won't.
  3. Garrett
    Garrett
    Apr 21, 2001
    33,601
    2
    167
    +4,471
    Just wondering since they play Jpeg and other stuff connected with the PC.
    Mmmmm it thought there was a way to encode film snippets on a CD so they would play as a film VCD??????
  4. Easy2BCheesy
    Easy2BCheesy
    May 8, 2003
    343
    16
    Depends on the DVD player. Some will play VCD, some will also play SVCD. Some will play MPEG and AVI clips recorded raw onto the CD. Others won't.
    What I meant in my reply is that you couldn't go to GAME and buy, say, a copy of Medal of Honor and expect it to work on your DVD player!! :)
  5. Kevo
    Kevo
    Aug 23, 2001
    5,364
    Manchester
    +146
    I can play MOH on my DVD player.
  6. Garrett
    Garrett
    Apr 21, 2001
    33,601
    2
    167
    +4,471
    :) Is that a Playstation, X-Box or PC DVD player?
    Or do you mean the video footage?
  7. Kevo
    Kevo
    Aug 23, 2001
    5,364
    Manchester
    +146
    X Box :)
    Sorry, couldn't resist,
  8. Garrett
    Garrett
    Apr 21, 2001
    33,601
    2
    167
    +4,471
    I knew something more than 12 inches was afoot.:D
