Will DivX players also play XviD?
Discussion in 'Blu-ray & DVD Players & Recorders' started by FunkyT, Mar 22, 2006.
  1. FunkyT
    FunkyT
    Nov 13, 2005
    95
    I'm thinking of the Pioneer DV-380 - can I do better for sub £100?
  2. Barbara2001
    Barbara2001
    Oct 10, 2004
    357
    28
    +23
  3. Hkan
    Hkan
    Pioneer DV-380 does play Xvid, how ever you should remeber that it's only DivX® Certified and not Xvid. But so far it has played all Xvid i've tested.
    /Håkan
  4. FunkyT
    FunkyT
    Nov 13, 2005
    95
    I was thinking of getting mine from AV-LAND for £80 delivered - good supplier?
  5. NX3
    NX3
    Dec 4, 2002
    3,493
    103
    +8
    The pioneer imo is a good player, no problems with xvids par packed bitstream. Many players have that issue but its easy to fix before you burn.
    Avland, good in my experience
  6. FunkyT
    FunkyT
    Nov 13, 2005
    95
    Thanks. What is the problem with packed bitstream? Is this a common problem with all XviD/DivX compliant players?
  7. flangemonkey
    flangemonkey
    Nov 27, 2003
    379
    28
    +59
    Many players will get tripped up by packed-bitstream-encoded vids.
    Use MPEG Modifier to determine whether your Xvid has it, then just unpack to a new file, then burn that file to the disc to view on the standalone player...
    Dead easy.
