will connection work ok?
Discussion in 'Cables & Switches' started by Lennyz, Oct 25, 2004.
  1. Lennyz
    Lennyz
    Jul 27, 2002
    339
    Cheshire
    +13
    I have just ordered a Humax 8000t 80gig and intend using it on my Pioneer mxe plasma but I also use an old Grundig Sat decoder which I am have connected through a JS rgb scart to vga converter at the mo.
    I just want to know whether I can output rgb scart from the humax looped through the grundig decoder and out to the js box to vga...or will it not pass through the rgb signal?
    I just don't want to have to buy a splitter if I can help it.
  2. Lennyz
    Lennyz
    Jul 27, 2002
    339
    Cheshire
    +13
    Anyone?
    Maybe I should have posted this in the PVR section of the forum?
    :blush:
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    depeding on box one of them will probably do pass through....give it a go...sonn find out if it wont!
