Will any of these lenses do macro?
Discussion in 'Photography Forums' started by Bales1983, Dec 21, 2006.
  1. Bales1983
    Bales1983
    Hi all,
    Looking at the canon 400D from jessops with the kit 18-55 a tamron 70-300 and im looking to buy a 50mm canon too.
    Will any of these do macro??
    Also weighed this up from pixmania for a tad over £700
    1 Canon EOS 400D + EF-S 18-55 mm lens
    £ 479.90 Inc. VAT
    1 Canon EF 50 F1.8 II standard lens
    £ 73 Inc. VAT
    1 Sigma Lens AF 70-300mm F4-5.6 Macro Super II
    £ 102 Inc. VAT
    2 Pixmania Memory card CompactFlash 80x 2 GB
    £78 Inc. VAT
    I assume with that I could do macro with the Sigma, but at 70mm wouldnt i need to be a far way from the subject?
    And can anyone recommend a good wide angle lense?
    Lee
  2. Valleyman
    Valleyman
    Dec 7, 2005
    713
    London + Tonbridge (Kent)
    +75
    The Sigma isn't a true Macro it's a 1:2 macro, which means it'll focus at double the distance of a true macro lense. Therefore the subject will be half the size than true macro.
    It's a reasonable place to start though if you're interested in close up. After all decent macros start at around £220 on import.
    If I were you i'd upgrade that sigma to the APO version. It goes from being a very very average lens to one that fires well beyond it's price bracket. You can get a 70-300 Sigma on import for about £125. Well worth it. If you don't want to go import, or don't wanna spend the extra cash the Tamron 70-300 LD is superior to the Sigma 70-300 non APO, and can be grabbed for £100 on special offer in a few places.
    Everything else looks good!
    Edit: For wide angle you'll probably find the Sigma 10-20 very popular on here. An alternative is the Tokina 12-24 which is a nice, solid lens but hard it's hard to find and is often a bit pricier than the Sigma due to it's rarity.
  3. senu
    senu
    Aug 26, 2005
    19,349
    Denham, South Bucks
    +2,811
    Why not use the kit lens for wide angle a bit before shelling out?
    For the APS-C sensors such as 400D 28mm is about 17-18 mm . The "real" wide angle lenses seem rather costly ( £300 upwards) :I'm sure suggestions will come
    I replaced the kit lens with the 17-85 mm EF-S USM IS : It cost £400 ( in March) I'm (very) happy with it as an everyday lens as the IS makes up for the f4 max aperture a lot of the time. It doesn't do Macro:nono:
    The 50mm f1.8 Mk2 is very fast and sharp ( though feels cheap and flimsy) but is very good for the £50-60 it costs: no macro there:(
    Ive just got the Sigma 70-300 DG APO Macro . Im still RTFM:rolleyes: but others who have used it ( and the Tamron) have posted great macro images with it . This lens is better than the non APO or Tamron though ( and costs a bit more) but YMMV. It has max of f4- 5.6 and for its cost no IS so tripod/ shelf / steady hands are a must
    Just do a search on these forums and see user opinions/ Images. There are a few. It only does macro at the 200-300mm range. It does a 1:2 macro but you might not find that a problem
    I got the last 2 lenses from Here the prices seem keen and although I picked them up in person I would recommend them
    PS Just read Valleymans post ( we were posting simultaneously) The Sigma 10- 20 is justifiably well liked and for £260- 300) may remain with you for long especially if you do more of photography that benefits from wide angle
  4. jomike
    jomike
    Nov 5, 2005
    2,160
    116
    Frimley, Surrey
    +525
    A couple of macros done with my Nikon D50 and Sigma 70-300 DG APO Macro. The flies were hand held, mosquito and spider on a tripod.
    Regards, Mike
  5. beachy
    beachy
    Oct 20, 2005
    1,317
    48
    +62
    got the sigma 70-300mm apo last week, a couple of test macro shot's with it, just cropped and sharpened a tad, great lens for the price but still yet to have a proper play with it.
    [​IMG]
    [​IMG]
    that's how much money i had left after paying for it :D
  6. senu
    senu
    Aug 26, 2005
    19,349
    Denham, South Bucks
    +2,811
    Mike, do you have a little insect collection in your garden??:rotfl:
    Nice shots BTW :smashin:
  7. senu
    senu
    Aug 26, 2005
    19,349
    Denham, South Bucks
    +2,811
    No.. did you have to walk home then??:D
    ... that just about buys half a litre of petrol and is less than minimum bus fare in here London:rotfl:
    The current atrocious weather is thwarting all attempts to put mine to any use just yet!
  8. jomike
    jomike
    Nov 5, 2005
    2,160
    116
    Frimley, Surrey
    +525
    Not just my garden! The (dead) mosquito was on the windowsill and the spider on the lounge ceiling.
    Regards, Mike
