Sunshinewelly
I have a sony 75 inch tv which has a 400 x 300 wall bracket (standard type of wall mount ie 2 vertical bars which hook onto plate secured to wall )
I am looking at a 85 inch Samsung which has a 600 x 400 vesa spacing - tvs are same weight
I used fisher bolts to secure my plater to wall and ideally would like to use the same mount rather than having too drill further fixing holes as i have a plaster board wall with a cavity and then a brick wall behind. the current mount is very secure etc
hence will my current count work?
