Will a US purchased Pioneer DVD recorder work in the UK?
Discussion in 'Blu-ray & DVD Players & Recorders' started by ensyed, Dec 30, 2006.
  1. ensyed
    ensyed
    May 25, 2006
    675
    +6
    I just moved to London from NY and have a one year old Pioneer DVD Recorder. If I use a buy a transformer to deal with the voltage difference, will this device work with Sky? the transformer is going to be expensive (100+) and at least my local hardware store wont take it back.
    Any BTDTs?
  2. sbowler
    sbowler
    Mar 24, 2005
    3,799
    Leeds
    +481
    I would very much doubt it would work. The TV standard of NTSC will probably be the only standard it would record in. You could try looking on the manufacturers website and checking the specifications for it. I wouldnt go splashing out on that transformer before i knew for certain though.
  3. ensyed
    ensyed
    May 25, 2006
    675
    +6
    I should have sold it before I moved. No point in holding on to it for 3 yrs.
  4. JH4
    JH4
    May 6, 2003
    2,463
    83
    +299
    Check the manual - some Pioneer's will record PAL and NTSC.
  5. mray
    mray
    Feb 16, 2004
    2,772
    83
    London
    +234
    Won't a step down converter do the job? They can be had for around £20 if you do a search.
