Will a UK Spec TV work in the Netherlands?
Discussion in 'General TV Discussions Forum' started by njr, Nov 7, 2004.
  1. njr
    njr
    Aug 23, 2002
    113
    16
    Berkshire
    I have just replaced my Sony KV28FX60 television with a new Plasma screen. I have a relative who is interested in buying the Sony for a knockdown price, but they live in Holland. Does anyone know whether a UK spec TV will be OK to use in Holland? I think they will be using it on an analogue cable network.
    Cheers, njr
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    NJR,
    Terrestrial analogue won't be any use because the sound/vision carrier spacing is different (so no sound).
    Depending on the exact parameters, feeding it from a STB with video and audio will probably be ok.
    Don't forget to factor in the transport costs, if any.
  3. red16v
    red16v
    Aug 20, 2004
    552
    +5
    njr, as 'Tightgit' says this is a uk spec tv so it won't work in Holland because of the different vision/sound separation of our analogue service compared to Holland's. However, this is a reasonably modern set and could be/may be multiregional - could be a simple set up in a menu. Before you discount the possibility I think it would be worth a call to Sony to double check first. regards, yt.
  4. boksbox
    boksbox
    Dec 1, 2003
    671
    28
    Chelmsford
    +90
    Whilst they won't get sound it might be worth having a word with a TV engineer if you know one, a few years ago I brought back a portable TV to England that I'd been using in Holland.
    A TV engineer friend coverted it for UK sound use, the component cost 50p so it would be worth looking into.
  5. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,318
    Somewhere in South Yorkshire
    +5,671
    The cheapest way to get round this problem (if indeed it is a problem - that depends on the TV) is to use a cheap locally-sourced VCR as a tuner. Connect it to the TV via AV or SCART.
  6. red16v
    red16v
    Aug 20, 2004
    552
    +5
    With respect, the cheapest option in the first instance is to ring Sony and ask if it can be set up to work with Holland's analogue tv system - only then need you consider spending cash. Regards, yt
  7. njr
    njr
    Aug 23, 2002
    113
    16
    Berkshire
    Thanks for the replies!
    I'll speak to Sony and see what they say. I suspect it is likely that a simple configuration change in the service menu will do it, but lets see. If it's not possible, its going in the classified ads!
    Cheers, njr
