Will a telephoto lens for s602 fit s7000?
Discussion in 'Photography Forums' started by spiderman999, Jul 16, 2005.
  1. spiderman999
    spiderman999
    Aug 5, 2002
    470
    Isle Of Wight
    Will a telephoto lens for the Fuji s602 fit the s7000?
    Regards Spidey
  2. Crocodile
    Crocodile
    Nov 4, 2002
    18,325
    +6,858
  3. spiderman999
    spiderman999
    Aug 5, 2002
    470
    Isle Of Wight
    Thanks for that. I've taken a gamble and bought a Raynox Lens off ebay for £26.50. The seller seems to think it's a 52mm fitting, and I was sure the s602 & s7000 used the same adaptors and they were compatible, and your pointers confirm that.
    Thanks for help! :hiya:
