will a system sound different if you change the display?
Discussion in 'AV Receivers & Amplifiers' started by Gary D, Apr 22, 2005.
  1. Gary D
    Gary D
    Jan 9, 2002
    7,770
    +826
    Hi chaps,
    this is not just another chance to show off my new screen - well it is but i have a serious question.
    in the picture below you can see my new setup. Where the plasma screen is now used to be a 36" Tosh CRT (which weighed 80kg's)
    now my question is - because there is no longer a large TV in the way will the sound field be different? My wife mentioned to me that she thought it sounded better than it had before and to be honest i thought so too.
    what do you think?
    Gary
    [​IMG][/URL][/IMG]
  2. Kier
    Kier
    Nov 21, 2004
    130
    Reading, UK
    Yes, without the big block of CRT between the speakers the sonic image should be far more detached from the speakers.
  3. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    man eltax speakers are good value :thumbsup:
  4. rjstott
    rjstott
    Feb 23, 2005
    14
    Assuming that the speakers were lined up with the front of the TV then the direct audio path would not be affected. However, there is probably a perception issue now as the image has moved relative to the sound field.
    There may also be reflection issues as a result of a change to the room acoustics.
  5. Gary D
    Gary D
    Jan 9, 2002
    7,770
    +826
    i like them :thumbsup: and they do sound really fab now :thumbsup:
    the ones you can see in the picture are filled with sand!! i cant lift them on my own :D
    Gary
  6. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    It makes for less vibration also. My crt used to vibrate like mad with two speakers next to it.
  7. CYRUStheVIRUS
    CYRUStheVIRUS
    Jan 25, 2003
    1,304
    41
    Brighton
    +14
    It might sound better if you take the remote away :D
  8. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    It certainly can make a difference, just think about where sound waves are going from out of your speakers - most of the treble will just come forwards from the tweeter but mid and bass frequencies will propagate from every side of the speaker rather than purely from the front baffle. This is particularly true of rear ported speakers.
    By removing the TV you change the way that any reflections from the rear wall reach you and the way that any sound travelling from the sides of the speakers interact with each other and the room. Of course much depends on the speakers, the size of the room, the distance between them, the size of the TV so obviously it's not an effect that's easy to predict the results of but I would generally expect them to perform better without a huge lump of plastic and glass between them. :)
  9. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    Garyd, does the sand make a load of difference? i have the same speakers in black and have been thinking about sand for a while (in fact since the day i bought them) just never really got round to it.
  10. Gary D
    Gary D
    Jan 9, 2002
    7,770
    +826
    chedmaster, the sand makes a difference, it tightens the bass up and makes sure the driver units have no where to go other than the direction they are meant too :D the added advantage is that they weigh about 40kg's each so they cant be nicked :rotfl:
    it will cost you no more than a tenner to but sand in them - its one of the easiest upgrades you can make and i think it makes a fair differance
    Gary
