will a Quintro do this, or what do I need?
Discussion in 'Cables & Switches' started by nathsea, Sep 21, 2004.
  1. nathsea
    nathsea
    Apr 26, 2003
    920
    +24
    I, as many of you do, have lots of sources!!
    I need a switcher that will allow me to plug all of my sources in to the back and then allow me to choose which display it goes to.
    For example I want to plug all my sources in and be able to switch between them going to the TV or the Projector.
    Hope this make sense? So what will allow me to do this, or do I have no chance!!
    Many Thanks
    Nathan
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    quintro has 5 inputs and 1 output scart
    or you can reconfigure to have
    4 SCART inputs and 2 SCART outputs
    (any input can goto any output)
    or
    3 SCART inputs and 3 SCART outputs
    there are also 2 pair of composite outputs duplicating the dedicated SCART output
    is that any help?? for £60 it's well worth the cash.
  3. nathsea
    nathsea
    Apr 26, 2003
    920
    +24
    superb , thats just what I wanted to hear!
    where can you get it for £60??
    And is it all remote control?
    Nathan
  4. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,702
    The Borders
    +3,071
    Hello both
    Does the Projector have a SCART input?
    Best regards
    Joe
  6. nathsea
    nathsea
    Apr 26, 2003
    920
    +24
    Joe,
    Yep it sure does, well it has a breakout lead to connect to the rgb sockets, why do you ask ?
    Nathan
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,702
    The Borders
    +3,071
    Hello Nathan
    Not all projectors have a SCART Input socket - so adding a SCART switcher ahead of the Projector is not always viable!
    Keep in mind also the B-Tech Quintro+ may be splitting the incoming signal (resulting in a lower quality signal) rather than duplicating it to the twin outputs - I don't have a manual here to confirm which way it works; it may be best to test one in your system before you confirm an order.
    Best regards
    Joe.
  8. nathsea
    nathsea
    Apr 26, 2003
    920
    +24
    Thanks for that Joe,
    Test one? Do companies let you have stuff on trial, or do you mean buy it and then return if no good?
    Hadn`t thought about it splitting the signal. That could be a problem , I would thought it should switch due to its setup.. but you never know.
    Many Thanks
    Nathan
  9. tuono
    tuono
    Sep 3, 2004
    47
    Careful .........
    I too thought that Quinttro was the answer (2 RGB outputs) but it kept changing the output to widescreen :suicide:
    Keene said they (and manufactures) are aware that this can happen sometimes but are (currently) at a loss as to why :confused:
    Keene took it back and are giving a full refund :smashin:
    They (Keene) say they know of no other device which will do this (normally second video output is for VCR so no 'demand')
    Anyone know any better :lesson:
    Best 'solution' (2 input to 2 output) seems to be drop RGB and go SVideo. Plenty of these switchers around
  10. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,702
    The Borders
    +3,071
    tuono
    I cant retain auto wide screen switching for you and its four times the cost but we can provide a very high quality 4 In 2 Out solution that definitely wont mess up your RGB+C signal.
    See http://www.zektor.com/hds42/index.htm
    Best regards
    Joe
  11. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    every online shop in the UK lets you try one for 7 working days
    starting from the day after delivery. That's the law!
  12. tuono
    tuono
    Sep 3, 2004
    47
    Thanks Joe...looks the biz but it is a bit expensive :rolleyes:
    It also does much more than I need since all my audio signals go through my AV
    (Also I can see lack of widescreen switching being a pain and for 4x cost I'd like it 'perfect' ;)
    Hmmmm maybe not that expensive
    http://www.ramelectronics.net/html/kd-msw8x3.htm :eek: :eek:
    :D :D :D :D :D :D :D
