Will a Mordaunt Short 905 Centre Open Up Front Soundstage more
Discussion in 'Home Cinema Speakers' started by Glenzo, Sep 20, 2005.
  1. Glenzo
    Glenzo
    Sep 3, 2004
    895
    32
    Co. Armagh
    +52
    :confused: I've been toying with the idea that I'd like the Front ie. Centre Soundstage widened more. Especially now that my new CRT TV has a larger top!!
    Currently I have a Tannoy Mercury MXC-M in the centre. Similar to:-
    http://www.tannoy.com/MERCURYFC
    Would a centre like a Mordaunt Short 905c open things up more or would this be futile to upgrade to?
    See My Profile for my current Set Up spec.
    Cheers!!
  2. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    If you want the front soundstage opened up more it sounds more like a speaker matching and/or positioning problem that you currently have.
    The ideal is for three identical speakers across the front, failing that a dedicated centre from the same range as the main speakers as that way you will have a tonal match and conversely if you buy a centre speaker that sounds completely different to the mains you will notice everytime a voice or sound pans across the soundstage.
    When asking for advice on centre speakers it is always a good idea to list your main speakers in the post as people (me included) won't be bothered to look in your profile :)
  3. Glenzo
    Glenzo
    Sep 3, 2004
    895
    32
    Co. Armagh
    +52
    My main speakers are JPW 205 floorstanders. Now I would have liked the 208 Centre but they're no longer available.
    Now I thought then similar brands, and UK made quality would be a way of getting a good tonal match. Also looks wise the MS 905 blends in as if it were part of the range.
  4. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    I don't know where MS actually make their speakers but JPW used to be made in Plymouth by a company that made speakers for quite a few other brands. Possibly you may find a closer tonal match than you think.
  5. Glenzo
    Glenzo
    Sep 3, 2004
    895
    32
    Co. Armagh
    +52
    That would be great!!
