will a modified uk xbox work on xbox live
Discussion in 'Xbox Forums' started by toxicmango, Jan 9, 2005.
  1. toxicmango
    toxicmango
    i have a pal xbox which i am thinking of modifying. if i do will it work on xbox live.
    Also if i modify the xbox will i be able to play pal games on hi definition mode
    thanks
  2. thfccambs
    thfccambs
    Jul 17, 2002
    19,091
    White Hart Lane
    +5,151
    Do a search,theres loads threads on the subject m8,and yes pal games will play in HD if x-box is set at NTSC.You will have to be the right leads.
  3. inzaman
    inzaman
    Dec 16, 2002
    7,887
    Derby
    +939
    If you can turn the chip off then yes you should be okay on live, but i think that MS do a lot of checks when you hook up to live.
    As above let search be your friend :)
