Will a Grand Cinema bracket fit a Domino 20?
Discussion in 'Projectors, Screens & Video Processors' started by M&Kfan, Jul 29, 2005.
  1. M&Kfan
    M&Kfan
    Hopefully a simple question. I have a brand new Sim2 Grand Cinema line projector wall/ceiling bracket. Code on the box says "HT BRKT-B". I opened the box last night and the instruction manual referred to the HT200, 250, 200 dual mode & HT300. Without me unwrapping and pulling apart the bracket to test it, will a Domino series project fit in this mount? Thanks in advance as I can't seem to find any information on the net about this bracket. Otherwise, I'll just put it up on eBay to get rid of it.
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    M&Kfan
    The bracket will be fine for a Domino 20.
    The Sim2 Bracket fits all the single chip models.
    Jeff
  3. M&Kfan
    M&Kfan
    Thanks for the quick response Jeff. Much appreciated :smashin:
