Wildcard Search on DVD-Soon
Discussion in 'Movie Forum' started by antomack, Jan 3, 2005.
  1. antomack
    antomack
    Jan 12, 2004
    40
    Dublin, Ireland
    Is it possible to do a wildcard search on the DVD Soon powersearch and if so what is the wildcard character that one can use? I have tried * and # without any luck. I'm trying to do a search on all titles with a cost under a specific value.
  2. Fatti
    Fatti
    Oct 22, 2002
    658
    Worcester
    +40
    In powersearch you have a price option of either 'Less Than' or 'More Than'. Select 'Less Than' then put the amount in CAD$ in the adjacent box. If all the other fields are left as default and you do a search, all items below that price will be displayed.
    Hope that helps...and apologies in advance if I've misinterpreted what you've said and it's no help at all :)
  3. antomack
    antomack
    Jan 12, 2004
    40
    Dublin, Ireland
    Thanks Fatti, that's exactly what I meant. Had tried that on my work PC and kept coming back with no results but it works on my PC at home; don't know why?
