Wild Bunch problem. Help!
Discussion in 'Blu-ray & DVD Players & Recorders' started by charker, Jan 21, 2008.
Thread Status:
Not open for further replies.
  1. charker
    charker
    Aug 4, 2002
    402
    +21
    Quick question.
    I imported the Wild Bunch on HD-DVD and it refuses to play with "Can't read disk".
    I read elsewhere this is an XBOX-360 issue and all disks will fail
    Anyone got this disk and have it working on XBOX drive?
    Cliff
  2. shagaboopon
    shagaboopon
    Nov 22, 2006
    3,279
    North Yorkshire
    +367
    Clear the cache for your HD-DVD drive in the system settings blade on the 360 under memory. Make sure you have the HD-DVD updates then try again. I haven't heard of any issues but that doesn't mean that they don't exist.
  3. charker
    charker
    Aug 4, 2002
    402
    +21
    That worked :clap:
    Never seen that memory option before, many thanks
    Cliff
  4. shagaboopon
    shagaboopon
    Nov 22, 2006
    3,279
    North Yorkshire
    +367
    No problem, glad I could help. I had a similar issue with Transformers that was fixed the same way, guess its the hazards of owning a add on system rather than one built from the ground up for the job.
  5. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +8,967
Thread Status:
