Wil TY-FB8HM work on TH-42PW?
A
arntos
Hi!
As the headline says, wil the TY-FB8HM work on a PW7 and be able to give piqture in 720P and 1080i in 50HZ?
arntos
MAW
It 'might' work, but not at 50Hz, and I think merely inserting it could invalidate your warranty, it is, as mep says, meant for 8 series.
aubi
The card that came with the 7 series did work on the 6 series. This is what the guy that sold me the PW6 told me, and he "had it checked".
He is not selling plasmas anymore and can't answer this question.
Technically there is no reason why it should not work in the previous series, and no reason for the manufacturer to tell us so.
MAW
Er, not so, mate. The 8 board is listed for 8 series plasmas only. All boards for the 6 work on the 7, except for a couple that are specific. They too have '7' model numbers, not '6' like the rest.
aubi
The 7 series HDMI board wasn't supposed to work in the 6 series iaw manufacturer, and that's my point. What is possible, even if it's not listed by the manufacturer?
MAW
Well, the 7 series HDMI does not work with the 6 AFAIK, the DVI does, but not very well. The 8 series board is actually marketed as 'only for 8 series' so try it at your peril.
Trending threads
