Wiimote battery life
hutch
3 days solid and still showing as full !!!
How the hell does that work :eek:
fizzgog
steggy
I'm down to two bars on one remote. Still waiting for my charger from amazon. Hope they hold out long enough.
I blame my 10 hours on Zelda for this :D
Mafro
Mines is starting to get pretty low after roughly 30 hours of playing.
willp2003
I put a couple of high power rechargable ones in mine and there still on 3 bars. i've turned off the sound and rumble to save power tho.
dan1979
There's a batter indicator somewhere on the main menu screen. Also if you press a button on the controller when the machine is off the number of lights that flash is how many bars of battery life are left.
hutch
press the home button at any time and its at the bottom of the screen :)
Pillow Lover
Pressing the any button on the controller when the console is switched off works too.
It will briefly flash the number of lights, ie 1-4 depending on how much battery is left.
I was going to buy some rechargeables for it it but ending up buying a 36 pack of AAs from Costco instead. Should last ages.
RDB :)
norealplan
Wilko's are doing rechargeable batteries cheap right now, 4 for £4.99 or charger and 4 batteries for £6.99.
I've replaced my batteries, but have been playing it quite a lot, and usually involves the nunchuck.
moofie
From the hours clocked up on the Wii messageboard thingy, I got about 25 hours out of my packed in batteries.
MANGABOY
http://www.firebox.com/index.html?dir=firebox&action=product&pid=1625&src_t=sbk&src_id=usbcell
If anyones going through batteries on their Will remote pretty quick an alternative could be getting usbcell batteries at the above link. They recharge simply by unscrewing the top and plugging into any USB port. Ingenius. They got pretty good reviews. They come in packs of two at £12.95, so I've ordered two, one set to go in my Wii remote and the others to go into the 2 wireless mice I have
marcstang
I clocked up 19 hrs on Zelda, at least 2 hrs on the menu and wii creation, and approx 3-4 hrs on wii sports, and my battery indicator still shows it as 3/4 full.
With a bit of luck it won't run out till my charger and re-chargeable batteries arrive though :thumbsup:
kreeeee
They're meant to have very poor battery life as they have a very low rated mAh rating.
Mafro
I wonder how long it will be before someone releases a rechargable battery pack.
danvitale
Its a shame Nintendo couldnt bring out a play and charge equivilent.. the console does have a USB port in the rear....
Latest News
Hisense TVs get Disney+ on VIDAA smart OS
  • By Andy Bassett
  • Published
Astell&Kern launches entry level SR25 MKII portable music player
  • By Andy Bassett
  • Published
LG rumoured to release 97-inch OLED TV in 2022
  • By Andy Bassett
  • Published
What's new on Blu-ray (UK) for Halloween 2021
  • By Mark Costello
  • Published
AVForums Movies Podcast: 20th October 2021
  • By Phil Hinton
  • Published
