first time poster here so Im hoping I can get some help.
I have a Wii but the machine will not pick up the controller nor the sensor bar.
Is there some kind of fix for this.
If they do and it's just the movement of the controller (the little finger on screen) that isn't working then i would say it's the sensor bar thats goosed. get a new one
Thanks bJarvis, turned out to be a dirty connection between the controller and nunchuck. a quick clean out and new batteries and everythings back to normal.
thanks all....
