wii with component cables - wavy lines across entire screen
Discussion in 'Nintendo Wii-U & 3DS' started by pikamookie, Dec 23, 2006.
  1. pikamookie
    pikamookie
    hi there. i am using wii component cables from yaointeractive with my dell 24" 2405fpw lcd screen. everything's plugged in and i get a blurry screen with moving wavy lines across the screen. when i put the resolution (on the wii) at HD, the blurriness and lines are worse than when it's on SD. i tried moving the cable away from my other things and switching power plugs for the wii, but to no avail. i can run gears of war beautifully on my xbox360 using the exact same ports on my monitor....
    any suggestions on tips or tricks to try?
    thanks in advance! happy holidays everyone! :clap:
    edit: just to clarify, the little moving lines span the entire screen and are in the menu as well as in zelda. they are horizontal as well as diagonal. thanks [email protected]
  2. Member 55145
    Member 55145
    Jan 18, 2005
    12,082
    +3,481
    try your 360 at 480p
