Wii update problem.
Discussion in 'Nintendo Wii-U & 3DS' started by thfccambs, Dec 23, 2006.
  1. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    Got my wii set up with my wireless network no problem.Done 1st update and nows started 2nd one.Been going for about 45mins and seems to be stuck at about 20%.:confused:
    Should i be worried,can't switch it off and try it again can i?
  2. dan1979
    dan1979
    Sep 16, 2004
    3,539
    83
    +218
    The wii frequently grinds to a halt when online, best off starting over.
  3. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    Thanks for reply,how do i go about this?I can't power it down can i?
  4. dan1979
    dan1979
    Sep 16, 2004
    3,539
    83
    +218
    Does the home button work?
  5. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    No.Not getting response from any buttons.:confused:
  6. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    Just unplugged it and it's started again,hope it's more successful this time.:(
  7. cheshire_carper
    cheshire_carper
    Jun 28, 2004
    692
    +83
    Maybe the update data is stuck in a DHL warehouse with all these German Wiis.... :D
  8. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    Seem to be having the same problem again,anyone else had these problems?
  9. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    Finally got it sorted.:clap:
  10. NX3
    NX3
    Dec 4, 2002
    3,493
    103
    +8
    Before you do any updates the Wii is uber fussy about wifi settings. While they work it sometime plays up, from what I've read on other forums. Once you've updated its a lot more wifi compatible. Might have been the reason why but glad the failed update didn't brick it for you.
  11. Te Bheag
    Te Bheag
    Sep 16, 2004
    459
    Wolverhampton
    +16
    Got any hints and tips for Wifi? I've yet to connect ours to the Buffalo wireless router... any help would be great! :lease:
  12. NX3
    NX3
    Dec 4, 2002
    3,493
    103
    +8
    Before the updates it can be quite fussy about what channel you use. If your having problems channel 1 seems to be the best bet. Also if WPA security isn't happy working (which you should use instead of WEP as WEP is easy to crack) try WEP or just for the update turn off encryption all together. Just while you do the update !!!! You should be ok with a Buffalo router, its based on the Broadcom chip set which is pretty good. Same as in a WRT54G, I had no problems even with DD-WRT running :D
  13. Te Bheag
    Te Bheag
    Sep 16, 2004
    459
    Wolverhampton
    +16
    Yup, I've got a WHR-HP-G54 and a 54S lurking around, so these shouldn't present too many probs. Thanks for the pointers. I'll be setting this up whilst the rest are getting ****** tomorrow! :rolleyes:
    BTW, for anyone looking for wireless router or access point, these are great value for money and are 'certified' with DS wifi, with AOSS setup.
  14. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    It was well easy to set up with wireless router,took 2 minutes.Unlike xbox 360.:thumbsdow
