wii on component
andyr300
the red and white parts carry the audio,you will need to plug those into the audio inputs of ur tv.
the red/blue/green bit is the video cable which as you say is working you must have got in the right holes!
you may just have the audio in the wrong set of inputs!
longster
cheers but I have the sound ones in correctly as Im getting sound from both speakers
Lin3ar
If everything is plugged in correctly it sounds as it either a)Cable is dodgy or b)Component input on TV is dodgy.
Have you anything else with a component connection to try to rule out the TV?
longster
I play my PS2 through my component so it cant be my TV, when I go on the screen set up menu on the wii I cant select the bottom option which is 480p, I can only select 50hz and 60hz
Lin3ar
When you use the composite cable you can't select 480p because the cable doesn't support it.You can only select 480p with the component cable plugged in(which is impossible if you can't get a picture in the first place)
longster
Ive sorted it, I had the bloody blue plugged in to green and vice versa :suicide: :suicide:
Cheers for all the help
T0rNaDo
so is this right then the component cables can only do 480P
on the wii's
T0rNaDo
oh :( no 720P then from the wii.
i also see no optical on it for sound.
stuck with 2 x phono i guess then :(
andyr300
yeh,no 720p..only hits 480p!
sound is pro-logic IIx compatible so it is surround in a way as i understand it
raigraphixs
just got GAME component leads (a bit misleading instore, as im sure the box on the shelf made them appear to be selling official cables, only when i opened it, i noticed the huge 'game' logo on box, but only (19.99) £17.50 (minus points on card), and so much better than the lead composite/scart.
Only problem is the sound is not working, when pluging the audio parts into the telly :thumbsdow . So i need to get a (coupler) and cables to extend to the amp for sound.
longster
is there any way of having both my wii and PS2 plugged into the component socket of my tv using a Y piece of some description, im sure ive seen a picture of them on this forum but I cant find it now
T0rNaDo
hmm wonder if i feed throu my amp it will upconvert it to 720P..
yer proberly soemthing your find easy on maplins website.
Beer Fury
This is my first post on this site. I can usually find the answers to my AV problems and sort them out. I reckon longster may be having the same problem as me. There are a couple of others with the same issue too and I'm wondering if it's even possible to sort it out! (Sorry if I'm being presumptuous about other people's woes by the way!)
My tv is an older LCD (Phillips 30pf9975) and I received a Blaze component cable yesterday for my Wii. The problem I have is that my tv doesn't accept 576i or 480i through component so I get a 'Picture format not available' message when I set the Wii away. The tv does do 480p of course but I can't see the Wii screen option menu to change the setting! I've tried blindly using the Wiimote and feeling the vibrations for the settings menu but it just isn't possible and the directional pad doesn't work so I'm stuffed.
I can't think of anyway in which to solve this and wonder if an update of some kind from nintendo would even fix it. It seems like quite an oversight by Ninty and it's seriously bummed me out!
mwatson800
Have you had other component devices plugged in Beer Fury? like a DVD player?
When you plug the component in and switch on the Wii it is sending the component signal to your TV. So it is just a case of cycling through your inputs on your TV...on the TV remote the button normally looks like this [<-]--
Beer Fury
Thanks for your reply!
I have my 360 hooked up through the component and that's no problem at all. I can select 480p and 1080i from the dashboard using the Phillips TV. The Wii however doesn't seem to work. I can view the menus and play games using the composite lead but when I hook up the component lead the tv tells me the picture format isn't available. If I could somehow change the menus on the Wii to the EDTV setting using the composite (not possible of course!) then hook up the component lead, I'd be away. My problem is still that the tv won't accept interlaced signals via component to allow me to view the Wii menu to change it to 480p and the Wii isn't doing it itself as I just have a big blue screen on my LCD!
I just figured when I bought the lead that it would be automatic but alas, nay! If I'm missing something obvious here, does anyone know what it is? 576i just doesn't cut it on my tv, feels like I'm wearing fogged up glasses!
Beer Fury
I've been thinking on this one. A friend of mine's buying himself a new HD set in the sales, so, with his being more up to date and hopefully able to handle 480i/576i over component, I'll take my Wii to his house, set it to 480p, unplug it, bring it home and hook it up to my tv. Then I should be sorted! Just an idea for anyone else having the same problem....:thumbsup:
Latest News
Starzplay streaming service rebrands as Lionsgate+
  • By Andy Bassett
  • Published
JVC adds Filmmaker Mode to latest D-ILA projector firmware
  • By Andy Bassett
  • Published
Bowers & Wilkins launches Px8 headphone
  • By Andy Bassett
  • Published
Sky set to launch its plug-and-play Sky Stream solution
  • By Ian Collen
  • Published
Movies Podcast: 26th September 2022
  • By Phil Hinton
  • Published
