Wii HELP - HDTV lead with 5 connectors. But only 3 on TV!
Discussion in 'Nintendo Wii-U & 3DS' started by SonyInDistress, Jan 18, 2008.
  1. SonyInDistress
    SonyInDistress
    I bought a new connector to connect my HDTV to the Wii. The old connector has 3 phono leads (1x Video & 2 Audio - I think) but the new connector has 5 phono leads. I've tried every combination of colours but best I can do is piture in B&W :-(
    Can anyone help!!
    Thanks.
    Peter
  2. lfcmonkey
    lfcmonkey
    Mar 26, 2007
    1,219
    Doncaster
    +105
    The lead you've got is a component cable which has 3 for the picture and 2 for the sound (all need connecting). It sounds like you haven't got a HDTV as nearly every hdtv has a component input. What make and model have you got?
  3. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    Just colour match yellow to yellow. You sure your using the right tv connections also ? They should also match.
  4. Kube
    Kube
    Mar 21, 2005
    5,384
    Armagh
    +369
    There are three picture leads (red. blue and green) and two audio (red and white). The old connector you speak of is composite, the new one you have is component. Different connection inputs. If its HDTV then it will have a component-in.
  5. m4rkie23
    m4rkie23
    Nov 30, 2007
    2,356
    63
    Gloucester
    +192
    The colours that will be on the component cable are as follows:
    VIDEO
    red
    green
    blue
    AUDIO
    red
    white/blue
    The video and audio may not be next to each other on the back of the tv?
  6. coluigi
    coluigi
    Jan 9, 2007
    1,290
    Manchester
    +86
    As an aside does anyone else think having a red for picture and a red for audio is slightly failure by design?
  7. Kube
    Kube
    Mar 21, 2005
    5,384
    Armagh
    +369
    Yeah, so much easier to have a black instead of red.
  8. G a f f e r
    G a f f e r
    Dec 31, 2003
    3,041
    U.K.
    +666
    I think the way that Nintendo does it is very good....a black "sleeve"/band around the Audio leads so you know which red belongs where.
    ......but, yes, maybe have a pink colour for Right Audio would work better (or red stripes rather than solid red)? (the problem is that the common colour for R is red.....L is white, but I've seen some phono leads where L is black).......
  9. SonyInDistress
    SonyInDistress
    Thanks Folks - got it. There were 5 phono connectors at the back when I took the TV off the wall. I had previously only saw the 3 on the side !!!
    Working great now!
