Just got a Wii Guitar Hero band in a box, it comes with a wired microphone which plugs into the Wii USB port.
On trying to get the mike to work it would not do anything, the instructions are minimal & just tells you to plug in & tap on it to make it work, which it didn't.
Strangley enough when we took one of the Wii remotes out of one of the other band items, it then allows the mike to be used, but it is wired into the console, so why should the wireless remote have any effexct on a wired mike?
Are we missing something here?
I would just like to point out that the Wii is our son's & we dont usually use it, but the Guitar Hero band was a present for ourselves to use, but my son has no idea about how the mike or usb's are supposed to work.
