jt2k6
About a year ago switched from broadband with talktalk to faster fibre 150 again from talktalk, came bundled with an eero 6 router, loved the interface but range was dreadful, worse than the broadband.
Talktalks solution was to ditch the eero, connect the fibre ONT to the old broadband router and send us a janky old WiFi extender. We have lived with it for now, but want to go back to the eero or similar, for the interface and parental controls, and have the following options
1. Get a second eero router and set up a mesh to hopefully increase range (about £70 on ebay)
2. Can get Tenda Nova mw12 3 pack for less than the cost of 1 eero (about £50 on ebay for 3 units)
3. Can get TP link deco m9 plus 3 pack for a little more thannthe eero. (about £90 on ebay)
4. Can get netgear orbi (rbk352) 2 pack if I push the boat out. (about £100 on ebay)
Current speed next to router is 125mb/s
live in a 1930's 3 bedroom semi, fibre comes into house in living room at the front, on the ground floor, down stairs is not too bad, including my home office under the stairs, the master bedroom is directly above the living room so signal is OK enough for using mobile phones on the wifi, the two kids bedrooms are where it gets a bit spotty, both with TV's with firesticks, phones, tablets etc..
Router is on table in living room next to the ONT, extender is plugged into socket in the upstairs hallway between the kids room
router is talktalk WiFi Hub
extender thingy is TalkTalk WiFi Extender
Would option 2 - 4 work with the gear I have (open reach ONT.... Nokia I believe if that helps)
Budget is tight as you may have guessed from the above options!
What would you do
What would you do
