Wifi internet connection - Help
Discussion in 'PS Vita Forum' started by superjim, Sep 10, 2005.
Tags:
  1. superjim
    superjim
    I connect to the internet with a usb modem, I am using a Linksys WRT54G as a router. I have my PSP wifi Connection working with my router a Linksys WRT54G. When I ping the IP address assigned to the psp it finds it no problem. I cannot get the psp to share my internet connection. Anyone able to help me with settings?
  2. -Spike-
    -Spike-
    May 17, 2001
    1,585
    E.Sussex
    +287
    Do you have WEP enabled on the WRT?
    If so you need to change to WPA-PSK for the PSP to work.
