Wifi enabled light switch
Discussion in 'Smart Home, Climate Control & Security Forum' started by ex_directory, Dec 21, 2016.
Tags:
  1. ex_directory
    ex_directory
    Jan 20, 2005
    222
    Cambridge
    +15
    What is the wifi enabled light switch that people are buying for controlling led lighting?
    I see Megaman do LightwaveRF switches which in turn can connect to their wifi hub.
    Any other options? Z-wave?
    My led's are just standard ones, not smart.
  2. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Depends what you want to do , basic Light control then possibly LWRF expandable Home Automation then Fibaro and Zwave
  3. ex_directory
    ex_directory
    Jan 20, 2005
    222
    Cambridge
    +15
    Thought so, have looked at all these technologies before and the intro cost is just to high. Especially when typically the only room you want to automate is the lounge.
    Surely, someone will come along with a wifi enabled light switch at some point.
  4. jk330ci
    jk330ci
    Sep 12, 2010
    1,184
    63
    Wales
    +127
    Will be soon. There is a boom in smart home tech so won't be long.
    I believe tplink may be bringing out a switch soon and if their smart plugs are anything to go by, they should be reasonably priced and work really well
  5. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    But probably look awful
  6. hort2074
    hort2074
    Apr 22, 2016
    1,095
    UK
    +311
    But that's just conjecture and you may be wrong.
  7. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    It is of course conjecture that's what probably means however large and white plastic is my best guess
  8. hort2074
    hort2074
    Apr 22, 2016
    1,095
    UK
    +311
    Based upon any sort of inside knowledge?
  9. jk330ci
    jk330ci
    Sep 12, 2010
    1,184
    63
    Wales
    +127
    Once one does it then others are sure to follow
  10. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Just experience of that being the chosen neutral colour for mass production
  11. irgsefton
    irgsefton
    Dec 21, 2007
    2,306
    116
    Liverpool
    +836
  12. elenardo
    elenardo
    Dec 21, 2016
    9
    4
    Europe
    Have you checked any of EnOcean switches? Are you planning to dim your LED (there is not much use in it for energy saving purpose since LED is already energy efficient, but just asking)?
  13. yoghurt
    yoghurt
    Jan 13, 2003
    662
    28
    +34
    That looks interesting . Does anyone know if you can also use this switch manually without it losing track if you then use Alexa please? Cannot see any mention of this on the spec .
  14. alabomb
    alabomb
    Dec 3, 2008
    68
    Reading
    +4
    Yep you can,
    The Smart Switch blends well with any room décor with its elegant, minimal design. Its LEDs can guide you at night when lights go off and you can simply turn it on/off by directly pressing.
  15. alabomb
    alabomb
    Dec 3, 2008
    68
    Reading
    +4
    Not to hijack but the only issue with that switch is that it doesn't dim. I have a living room with 12 Gu10s split between two dimmers.
    Any dimmer wifi switches out there??
  16. alabomb
    alabomb
    Dec 3, 2008
    68
    Reading
    +4
  17. elenardo
    elenardo
    Dec 21, 2016
    9
    4
    Europe
    I've found LED DIMMER SR-2836R by Sunricher. It's available from Amazon in Germany. No reviews are available, so it might be a pig in a poke unless some of this forum users has tried this product and is ready to share his feedback.
  18. ex_directory
    ex_directory
    Jan 20, 2005
    222
    Cambridge
    +15
  19. ex_directory
    ex_directory
    Jan 20, 2005
    222
    Cambridge
    +15
  20. jk330ci
    jk330ci
    Sep 12, 2010
    1,184
    63
    Wales
    +127
    Works out pretty expensive for the hub and switch, worth a go if you plan on expanding in to lightwaverf.
    I still think holding out for a new solution is the way to go or trying a z-wave module like the fibaro dimmers and a z-wave adapter loads of options there. Half the battle is tying all the different standard together
  21. hort2074
    hort2074
    Apr 22, 2016
    1,095
    UK
    +311
    Agree with this.
    I can't believe Hue won't come up with a better solution.
    All I want is the hue dimmer integrated into a normal switch, either replacement or cover.
  22. jk330ci
    jk330ci
    Sep 12, 2010
    1,184
    63
    Wales
    +127
    Iv seen people cover over existing switches and replace with the wall mounted remote control. It's not ideal but does work I suppose.
  23. Synchro
    Synchro
    Nov 14, 2004
    5,981
    Chester
    +1,519
    Then if your wifi is down, your lights don't work.
  24. jk330ci
    jk330ci
    Sep 12, 2010
    1,184
    63
    Wales
    +127
    I'm sure the hue remote is z wave and not hub/wifi dependent.
    Wifi switches would also be operable manually so no biggy if wifi goes down
  25. Synchro
    Synchro
    Nov 14, 2004
    5,981
    Chester
    +1,519
    Hmm, what makes you think the remote it's z-wave?
  26. jk330ci
    jk330ci
    Sep 12, 2010
    1,184
    63
    Wales
    +127
    Or zigbee which ever one hue uses.
  27. Synchro
    Synchro
    Nov 14, 2004
    5,981
    Chester
    +1,519
    Yeah, just checked and it's ZigBee
  28. jk330ci
    jk330ci
    Sep 12, 2010
    1,184
    63
    Wales
    +127
  29. Synchro
    Synchro
    Nov 14, 2004
    5,981
    Chester
    +1,519
    Yeah I'd seen that before. Not going to work for me. Maybe other people will find it useful.
  30. jk330ci
    jk330ci
    Sep 12, 2010
    1,184
    63
    Wales
    +127
    I'd rather a fibaro module tbh with a smartthings hub
