Wierd problem with Alba Freeview box
Discussion in 'Freeview & YouView' started by ianhpl, Feb 13, 2005.
  1. ianhpl
    ianhpl
    Jan 21, 2005
    23
    3
    I have used my Alba STBX3 freeview box without problems for several months.
    However I have upgraded to a Philips DTR 500 and moved the Alba to our Toshiba 28" widescreen. Simplest of connections just the TV and the Alba.
    I can receive all the stations and move between them using the remote without problem, problems start if I try to use any function buttons:
    e.g I press ok and the tv changes from ext1 to channel 7
    I press menu and the tv changes from ext1 to channel 2
    If i switch back to ext1 using the tv remote the function has worked but of course this is driving me crazy.
    Hope someone understands this and able to offer a solution
  2. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    Possibility the Alba's function buttons are the same signal as the toshiba try and cover the tv's remote receptor not a perfect solution but might help
    Jaymac
  3. ianhpl
    ianhpl
    Jan 21, 2005
    23
    3
    Thanks for that.
    Yes that is the problem fixed albeit in an inconvenient way.
    I'll check the manuals in the very faint hope they might provide a solution.
    Thank you
