Wierd Feature on Toshiba Rear Projection
Discussion in 'General TV Discussions Forum' started by gedclink, May 21, 2002.
  1. gedclink
    gedclink
    Model is 51 wh18b
    Trivial but puzzling!!
    Since having the television for over 6 months, I ALWAYS have to switch the set on by pressing the power button on the front
    ( which puts it into standy ) followed by a channel number on the remote which switches the set fully on. The instruction booklet informed me this was the normal procedure.
    A couple of days ago, I noticed that the television set now comes straight on when I press the front power button. You no longer need to then press a channel select key on the remote.
    1) Any ideas if I have done something?
    2) Will this cause a problem with the set, i.e was the " double " power up a safety feature?
    Thanks again
    Ged
  2. shaunthedude
    shaunthedude
    you can switch the tv off into standby and then press the button on the panel. When you turn the tv on again using the panel switch it will come into standby again. Maybe you just turned the tv off one night by just pushing the panel button and not putting it into to stanby first, therefore when you pushed the panel button next day the tv came straight on. Blimey Im confused now. I have the 42wh18b and i always just use the panel button.
    cheers
  3. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    I have the 42PW23P and when I push the on/off button it comes straight on unless put into standby before turning it off.
