widescreen
Discussion in 'Televisions' started by icequake2000, Apr 28, 2003.
  1. icequake2000
    icequake2000
    Jan 12, 2001
    171
    devon
    +16
    can anyone tell me if auto select widescreen swithches automatically on both rgb and normal scart connector from a sky box
    thanks
  2. figrin_dan
    figrin_dan
    Jan 9, 2003
    1,993
    +135
    Depends on the TV make and model
  3. icequake2000
    icequake2000
    Jan 12, 2001
    171
    devon
    +16
    my tv is a sony KV28LS35(S)
  4. Squirrel God
    Squirrel God
    Yes, it should do. Widescreen switching is carried in the scart. I'm familiar with your TV, but not with Sky digiboxes though.
  5. Orbitalzone
    Orbitalzone
    Feb 23, 2002
    394
    E.Sussex
    +43
    There shouldn't be any problems... I connected up a friends TV - the same model but in 32" size and it autoswitched nicely.
    The good thing is that you can view 4/3 in any mode you like, such as 4/3 (best IMO) Smart stretch-o-vision, 14/9 etc and when you select a digital channel that's broadcasting true 16/9 anamorphic widescreen (BBC News24 for example) the TV goes to the correct 16/9 'wide' mode.... when you go back to a non ' true 16/9' broadcast it goes back to your previously selected viewing mode.
    Most Sony widescreens seem to work in this manner. Another nice touch with most Sony widescreens is that you can alter the picture geometry (a service setup, not a normal consumer adjustment) and it can be varied for the different aspect ratios... so if the 4/3 mode needs a tweak then you can alter it but the alterations don't affect the other modes... handy for tweaking freaks. ;)
    I'm most impressed with my KV28FX20, the predecessor to this TV. Excellent pictures and reasonable sound quality for a 50Hz TV.
  6. Squirrel God
    Squirrel God
    The FX and LS sets are not related. Two separate product ranges ;)
  7. Orbitalzone
    Orbitalzone
    Feb 23, 2002
    394
    E.Sussex
    +43
    Wow a fast reply!
    and of course you're right..... they're not the same chassis at all..... and the LS has RGB centering I believe... most handy!
  8. Squirrel God
    Squirrel God
    I couldn't live without it now! 2 RGB scarts on the LS60 and it remembers the RGB shift value for each scart separately :smoke:
  9. icequake2000
    icequake2000
    Jan 12, 2001
    171
    devon
    +16
    thanks for the replys I managed to get it to work at the end. It looks like i have a dodgy scart lead.
