Widescreen Worries
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by PanMan, Jan 17, 2002.
  1. PanMan
    PanMan
    Jan 17, 2002
    50
    Dear All,
    I am considering the purchase of my first camcorder, probably the Panasonic NV-DS28, with a view to editing the results on a PC. I have a widescreen telly with which I will view the footage, so I would really like a camcorder that is best suited for that. I know the DS38 has a 'widescreen' option on it, but does the DS28? Does it just record two big black strips at top and bottom, and will I therefore be loosing quality when my telly effectively magnifies the picture?
    I would also like to output the footage to VCD, and eventually DVD when the hardware is a little cheaper. Is it possible to film in 4:3, and then reformat it to 16:9 on the computer software. Would Pinnacle 7 or Ulead 4/5 do this?
    So many questions....can anyone help?:confused:
  2. Doubledoom
    Doubledoom
    My Sony camcorder of about 4 years has a 4:3 mode, letterbox mode and an anamorphic 16:9 mode.
    I wouldn't be surprised to see an anamorphic mode on many of them nowadays.
