Widescreen Tremors
Discussion in 'Movie Forum' started by njm32, Dec 26, 2001.
  1. njm32
    njm32
    Nov 23, 2001
    22
    3
    Dorset
    I have a widescreen(1.85:1) 'collector's edition' of TREMORS which will not play with the correct aspect ratio. With my widescreen TV set to wide the picture is a 'squashed letterbox' format with the images too short and fat. I can get a semblance of the correct ratio by increasing the picture height in cinema mode on my Toshiba TV. Other DVDs I have all play OK with the correct ratio - it is just this one has the problem.
    Anyone else have this problem? Have I got a faulty disc? Is there something I have not tried?:(
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Sounds like it isn't Anamorphic.
    I have to play movies like that on Zoom mode on my Sony widescreen TV.
  3. tee
    tee
    Sep 17, 2000
    2,711
    71
    Close by
    +50
    I have the R1 version and it's definitely not anamorphic.
  4. mjn
    mjn
    May 24, 2001
    23,205
    Herts, England
    +11,423
    its one of those nice non-anamorphic pictures....!!
  5. njm32
    njm32
    Nov 23, 2001
    22
    3
    Dorset
    Thanks folks.
    OK so I have a non-anamorphic disc, but how should a properly set up player display the image? - with true image ratio, or, as I have, distorted (squashed) verticals. The zoom feature on the player expands both horizontal and vertical so this is not much use. My Toshiba TV has a 'cinema' mode which gives user control over height and width independently and this is the only way of viewing the picture in correct proportion.
    Also, if non-anamorphic versions are to be avoided, how does one tell the difference before buying?
    Cheers:confused:
  6. mjn
    mjn
    May 24, 2001
    23,205
    Herts, England
    +11,423
    anamorphic discs, will say "enhanced for 16x9 or widescreen tv's" on back of the packet under disc details.
    also on my sony Tv, i just use Zoom, which increases the height.
