Widescreen swiching with ntl cable box using Tosh 36ZP18P
Discussion in 'General TV Discussions Forum' started by plb, Aug 26, 2001.
  1. plb
    plb
    After switching on my ntl digital cable box the set for a few seconds' switches to widescreen then defaults back to 4.3 mode, I then have to manually switch the set to widescreen mode using the size button. It appears to work ok with my Sky digital box switching to wide screen correctly without any intervention from me. I have set the ntl cable box to the 16.9 widescreen option in the TV settings menu.<br />Any ideas??
  2. Doubledoom
    Doubledoom
    You haven't responded to the answers given to your same question posted at uk.media.home-cinema
  3. plb
    plb
    Sorry had a busy weekend, I will try as few things and get back. <img src="smile.gif" border="0">
  4. Doubledoom
    Doubledoom
    No problem. I wasn't sure you had seen it that was all.
