widescreen slideshow ?
Discussion in 'Photography Forums' started by army, May 29, 2003.
  1. army
    army
    Apr 24, 2003
    33
    Hello all
    I'm about to start scanning all my old photographs for archiving and to create slideshows on cd/dvd rom. Heres my question ---
    Is there software to create a slideshow on cd/dvd which will show the photos on a widescreen tele (16:9) without having to change the aspect ratio to fill the screen therefore distorting the picture.
    [Ive tried ulead picture show & roxio 6 with no success.]
  2. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Lytham St Annes, where people are put out to grass
    This is pure guess work, but i would guess its to do with the VCD standard being 4:3. Ulead uses the VCD standard for sure.
    Not tried it (only having a DVD RAM drive (thatll teach me to be an early adopter) ) but surely a DVD authoring tool would allow for a widescreen tag to be set? As you would be using another format that isnt constrained by VideoCD.
    EDIT:
    Ignore me you can do widescreen VCDs so its a limitation of software not VCD format.
