Widescreen resolution
Discussion in 'Desktop & Laptop Computers Forum' started by nickb23, May 16, 2004.
  1. nickb23
    nickb23
    Jul 21, 2002
    437
    Beckenham, Kent
    +14
    I have a fx5600, which i am starting to use the s-video of to watch DIVX films. My TV is a 32inch Widescreen, which is setup in the display properties as 720 x 576. Is this the correct display resolution for the TV. I know with DVD, Digital TV etc, that this is the only resolution, and if it is Widescreen, the picture is squeezed (if seen on 4:3 monitor). But as this is being 'used' as a second monitor, is this still the case. Also is Nview the only decent software for mutliple monitor displays?
    Also does anyone know of any good websites with information about setting up outputs for tv's
    Many thanks
    NickB
  2. stevieboyyyy
    stevieboyyyy
    Jun 21, 2004
    71
    Hampshire
    +6
    I'd like to know the answer to this as well!
  3. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,952
    Manchester, England
    +84
    That is the resolution of PAL DVDs so it's unlikely that many DIVXs will be more than that (most are a bit/lot less). Most domestic, widescreen TVs in this country would struggle with any significantly higher resolutions any way so it is probably your best bet. If you want to be sure you could try some different options but I'd imagine it is as good as you'll get with SVid.
    HTH
    Owain
  4. Whitey1977
    Whitey1977
    Jun 13, 2004
    475
    +42
    You will have to use powerstrip to create a resolution of 1024 x 576 @60Hz and then select this in the graphics card properties. This will show the desktop correctly on a 16:9 TV in 'wide' mode.
    Your DVD software and WMP will automatically show any files played in the correct aspect ratio.
    If you can not get this to work, there is a work around in the divx configuration to set the output to 16:9 even though the desktop resolution is a 4:3 res.
    Hope this helps
    Whitey
