Widescreen recording Pana DMR-E85
Discussion in 'Blu-ray & DVD Players & Recorders' started by sfox, Mar 12, 2005.
  1. sfox
    sfox
    I have my E85 hooked up as follows/
    SKY TV RGB scart to E85 AV2
    E85 AV! to TV AV1 RGB input
    SKY and AV1 E85 set to RGB
    E85 AV2 set to normal.
    I am getting RGB no problem.
    My problem is that I ma not recording the Widescreen switching signal.
    I set the E85 to record of AV2. The picture being diplayed is WIDE as shown on my Panasonic Widdescreen TV.
    When I play back the recording it is squashed and i need to expand by using the aspect button on my TV remote.
    What makes this weird is that it was working before I moved equipmet between rooms as I have a previous recording which when played sends the WIDE signal out and swirches the TV accordingly.
    I am baffled.
    I tried changing scart leads but same.
    TIA
  2. DVD-RAM
    DVD-RAM
    If the E85 is the same as the E55, it will only record in widescreen on DVD-RAM
  3. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    939
    29
    leeds UK
    +41
    It also should work from the hard drive,but will not work from a dvd-r recording
