Widescreen CRT monitor as TV
Discussion in 'Desktop & Laptop Computers Forum' started by HitmanIP7, Nov 5, 2004.
  1. HitmanIP7
    HitmanIP7
    Jul 16, 2003
    791
    28
    UK
    +25
    Ive been looking into getting a new widescreen CRT TV for use with my HTPC, but was thinking last night that perhaps I could get a widescreen CRT PC monitor and use that instead.
    I still prefer watching DVD's and TV on a CRT.
    So far Ive found one, the Sony GDM-FW900. Cheapest Ive found it new is around £1200 though!
    Anyone know of any similar?
  2. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    Seen them go on ebay for about £300 before, usually the silicon graphics branded ones.
  3. Gazebo2
    Gazebo2
    These monitors come up occasionally on Ebay - the last few have gone for between £100 and £500 depending on condition. Some have been by oems such as SGI & Sun, but are essentially are the same Sony model or an earlier Sony model - just search for widescreen in the monitors section. They also weigh 40kg or so, so expect to collect!!
    I was thinking of one of these to replace the 22" monitor, I'm currently using, what has put me off is that they are 16:10 widescreen (or put another way 14.4:9), so displaying an undistorted 16:9 image the image would require cropping or black bands at top and bottom.
    I was surprised to see that my ATI card supported at least one 16:10 resolution (1920*1200) without resorting to Powerstrip, but don't know what DVD playing software or the Nebula software would do if the signal was output at 16:10 resolution. Would any of the experts out there like to enlighten me?
    Martin
