widescreen camcorders
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by dexter, Dec 2, 2004.
  1. dexter
    dexter
    Jan 27, 2002
    214
    can anyone recommend a camcorder (the cheapoer the better!) that records in 16/9. I know one of the Sony DVD camcorders does - but the advice seems to be to steer clear of dvd camcorders. Are there any widescreen miniDV models out there?
  2. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    I have the Sony DCRPC100 which records in 16:9 depends if you want new or would be happy with previously owned. FWIW
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    Well none of the consumer camcorders currently do full resolution widescreen recording. Some of the new Sony models have 'true widescreen' that uses a slightly wider CCD that crops top & bottom for 16:9 and crops left & right for 4:3 which seems to be the best compromise at the moment as very little quality is lost for either format. All camcorders will do basic 16:9 recording, but many will crop a large section of the CCD so a fair bit of resolution is lost.
    Mark.
  4. griff_av
    griff_av
    if quality is an issue you might want to look at hiring an anamorphic lens >
    http://www.centuryoptics.com/products/dv/16x9/16x9.htm
    which will squash the 16:9 image onto the full area of the 4:3 CCD you would then have to use software or a company to process the recorded image back to 16:9 for editing
  5. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Look at the Sony HC40 this is the replacement model for my TRV33 and aeven though it is not quite as good as the TRV33 should be worth investigating.
    One thing though - mine uses more CCD for 16x9 so would look worse with an anamorphic lens
  6. Quilgy
    Quilgy
    Nov 19, 2003
    153
    London
    +12
    My Canon MVX3i uses an anamorphic process to achieve the 16:9 image. It does it very well too with no discernible loss of picture quality compared to capturing in 4:3, and full height (576) frame - i.e. - no letterboxing
    At first I thought it did this using an onboard anamorphic lens, but it is actually electronic, using a similar technique to what Mark said.
    I have seen the Sony DCR-HC4OE reviewed very favourably (in Digital Home magazine)
