wide screen option with 3802
Discussion in 'AV Receivers & Amplifiers' started by fan, Oct 13, 2003.
  1. fan
    fan
    I just discovered this option on my amp. does this work with dd5.1 sources? How often does everybody use this audio option, or does everybody just use the regular dd option? An what about stereo sources, do you use dpl2 or widescreen?
    frank
  2. Jase
    Jase
    Mar 16, 2001
    9,535
    UK
    +933
    Personally I think it's a bit naff and you're better off sticking with Dolby 5.1, EX or PL2 (depending on source). It's up to you though! :)
